I want to change my front rim and tire on my 2016 SG special. What is the largest rim and tire size I can have without replacing the stock fender? I dont mind adjusting the fender but just don't want to replace it.
I have a 14 SG, and I went with a 21” with the CVO Dunlop front tire (only mention it because it’s a fatter/thicker tire). I had to use the fender risers, and it fit perfectly. I’d imagine anything larger than a 21, you will run into clearance problems, even with the thinnest of tires.
