I need advice from the Gurus !!!
I did a stage 3 upgrade few months ago. The set up is the SE 114 kit, SE 515 Power Cam, Vance an Hines Hi Output slip-ons, SE Ventilator, SE Spark Plugs wires. After the upgrade, I was told to ride it for 1,000 miles then to bring it back to do the 1K miles check up and put the bike back on the dyno to "refine" the set ups.
I did that and when I picked up the bike, I was handed the dyno sheet.....the dyno results were as follows:
Before Dyno: Max Hp: 98.99 Max Torque: 92.50
After Dyno: Max Hp: 106.65 Max Torque: 107.08
I don't think something is right. I believe that the numbers should be a lot higher than that. I mean, the bike right out of the lot should have 111 lbs of torque and now, it is 4 lbs less with a bigger engine and a different cam.....
Even the bike feels different...before you could feel the spunkiness, the power, and now, it is almost like when I first took it out of the dealer...tamed, somewhat sluggish...to put in different perspective, in 5th gear, I could twist the throttle a little bit and the bike almost wanted to trow my lady out of bike....and now....it feels not quite the same.....
Any advice what should I do?
Should I take the bike to a different techs ( not Harley Davidson morons and have them re-dyno my bike?
Advice and inputs will be of great appreciation !!
