Oil pressure
Spamlmci
My oil pressure gauge decreases as the bike gets warmed up riding. After 25. Miles we stopped at red light oil pressure dropped to zero and oil indicator came on. Oil good
I'd recommend picking up a mechanical gauge to check it and see if the pressure really is zero to low or your OEM sensor is bad. If it really is that low you may have oil pump issues , what year is your bike ?
2010 glide. It goes from 30 to 0 gradually in 25 miles .temperature gauge 110°, weird, when light comes on she runs rough and the stalls.
You may be having a problem with your pressure relief valve. If the valve sticks open it will cause “ low oil pressure”. Check the “ https://www.baggersmag.com/twin-cam-oiling-system-basics-tech” and read article this may help you.
dednik
