Replacing the Front Brake lines
Streetglidejim
I am placing monkey bars on my 2016 Street Glide. I need to replace the clutch hose and the front brake line. I am trying to find out how to bleed the front brakes without bring it to the dealer. Any help would be great...
I used a break bleeder from harbor freight! Worked great!
Make sure when you have it apart and working on the brake you don't turn the key on. If you turn the key on unhooked you will have to take it to a dealer and have them bleed and reset the ABS. I had to replace the lines all the way from the ABS unit because of the fittings on the stock lines. Easy job if you get a mini or mighty vac brake bleeder and they are pretty cheap.
And by the way welcome to the fun
jdtech17
