I recently installed the SS HDHU14+ and I’m having a few issues with noise/rapid ticking/interference as well as updating the Firmware. I’m waiting to hear back from SS Tech support to troubleshoot my issues. One thing I noticed in their warranty policy is if you install it yourself the warranty is only 90 days and not 1 year if installed by one of their vendors.
I tried wiring via the RCA pre-outs (per the instructions), two different sets of RCA cables were tried (not cheap ones), RCA couplers (HU to AMP) to avoid RCA patch cables because the amp harness is long enough to reach, and even bypassed the RCA pre-outs instead wiring with high level and no changes, the noise/rapid ticking/interference was still there on all sources. I double-checked all connections; speakers, power and ground and all are tight, no breaks, no shorts, no issues. My system is grounded from amplifier negative post back to battery negative terminal post.
I contacted a few places for feedback regarding their installs and of course they said no issues. I didn’t have any noises, interference or Firmware update issues at all with HD HU 6.5 GT. The only thing that changed was swapping out HU’s and eliminating the axxess MLOC745 that was necessary with the HD HU 6.5 GT.
Even turning the gain down did not eliminate the issue.
Appreciate any feedback. Thank you.
2016 Street Glide
AMP: Stinger SPX700x4
Fairing: Mmats 6.5
Lids: Rockfords
2016 Street Glide
Fairing: Mmats 6.5
Lids: Rockfords
