Speakers are beeping Continuously 2015 Street Glide Special
TeamAZ
My speakers started beeping a couple of weeks ago due to what I thought was a battery that needed to be replaced. I have swapped out the battery and took it for a ride and the speakers are still beeping with and without the radio on. Any ideas?
Try turning your ignition on and immediately pulling the main fuse.... turn ignition off...wait two minutes... reinstall the main fuse.
Should reset the system.. but maybe not...
I have only seen this one other time... battery was drained and took out the regional code in the head unit. Check your head unit regional code.. I can't remember if you can do it yourself or you might have to bring it to the dealer
Sent from Note4 via TapaTalk
Thanks for the great advice! However like you said the issue with my battery did wipe out the code, so I have to go back to the dealer so the bike and info system (nav/radio) can be remarried. Nothing I can do from home.
At least you know how to stop the beeping. ... I wouldn't think they would charge you for it
MotorNed
