Streetglide hard lowers. HD or aftermarket
Can't wait to see them painted and installed Mojo. Seeing them on your bike may change my mind about putting some on mine.
TomA- They should be ready to pick up next Monday from paint shop. I'll post pics when I install them. I still have to cut some pieces to install behind the mesh grills for winter riding. I like the fact I can remove the solid pieces for cooler riding in hot weather and still have my Lowers on.
I finally ordered some lowers but from hogworkz.
I had 3 reasons.
My bike is vivid black so I wanted the black to match since I won't be getting the lowers painted, I like the older style lowers better (with the big sliding door for air flow), I didn't want speaker pods so I pay less and don't get those.
Tracking says I'll have them next Tuesday, so I will report back after that...
Thanks Mojo will be looking forward to the pictures. I'm at the point this week where I have to many projects going and I'm over whelmed. Time to have a beer and collect my thoughts lol
Interested to see how these work also. I ordered some oem ones from an online dealer last week . I didn't wanna chance the aftermarket ones due to my very anal expectations when it comes to my vehicles. They actually shipped today. Ready to get them on and expand my soundz level 4 audio.
I was wondering the same thing but also remember reading that someone (with a SG) was able to run both fork fangs and lowers.
That would be me. LOL I ran both. But I didn't installed as per the instructions. I reversed them with the curvature facing forward. AND I also trimmed them down a bit. So it can be done with a little modification.I have since removed the fangs after a very hot summer. Have not installed them since. I don't think I will.
I ordered a set of lowers last Sunday night from Calibiker on ebay for $154.95 in vivid black. They arrived Saturday morning and the paint was good and they were fully assembled. I ordered the $52.00 cnc mounting hardware from another ebay site and I installed them this evening with no troubles.
The paint matches and the fit and finish is fine. I have not had an original HD set of lowers before, so I cannot comment on the quality or if there are any differences between the two, but I am pleased at this point with my $200.00 investment.
I have the Harley wind deflectors on my SGS with Harley lowers. I just slid the wind deflectors forward when mounting and there is plenty of clearance. On Ultras, I think, the Wind deflectors have to be clearance to miss the extra lights.
I have the Soft Break +2". Does anybody know if I can get the lowers? I thought I read that with the +2 they would not work.
Thank you!
I think you are right about driving lights. After doing some online research it seems if you have only lowers and fork fangs all is well.
I installed one of my lowers yesterday. Seeing it is too cold to stay in the garage for a length of time, I only installed on the side of the bike that is not against the garage wall (didn't want to totally take cover off and move bike). BUT one think I can say is that with the fork fang and the lower, there was NO problem at all. NO modification needed - plenty of room to have both in place. Right side lower is on and I turned the handlebars all the way right without any issue.
Thank you!
Jimbo
I have the +2 Soft Break and it seems to work OK with my lowers. I have the Tall Boys extended floor board mount and Baker industries extended 1" floor boards. I also have their 3/4 or 1" spacer kit that pushes them out from the bike. None of that should have any bearing on where the pedal sits. It is tucked inside of the lowers a little but it hasn't creating any problems for me using it.
In response to another post I also have the fork mounted wind deflectors and have no clearance issues.IMG_3534.jpgIMG_3536.jpg
Msquad- Do you have the 2009-2013 style Lowers? I pick up my 2014-16 style from painter on Friday and it looks like my fork fangs won't work with them. I'll know for sure when I do an install report w/pics for SGF.
These are mine:
http://www.ebay.com/itm/HARLEY-2014...ING-FACTORY-FOR-HARLEY-DAVIDSON-/131238266188
I did not go with the same ones you got.
See post: http://streetglide.com/showthread.p...D-or-aftermarket&p=51991&viewfull=1#post51991
When it warms up I'll pull the bike out if its spot and install the other side and put up a pic or 2.
Picked up from paint shop today. They look marvelous! Mine are Fairing Factory but there is also Easyfairings and others out there. Most are quite different brand to brand. I'll post a complete install this weekend as promised
(stock photo)
OK Folks, Some of you asked me to do a review on the Factory Fairing brand of lowers available on eBay. After exhaustive studying all the brands out there, it appeared to me that this brand, Hogworkz and Easyfairings had some quality products at substantial savings**. My order for the new style 2014-16 Factory Fairings came quickly and even included a set of Speaker boxes as well and all for $249! I sent them off to the painter for a fresh coat of Mysterious Red Sunglo and got them back a couple of days ago. Everything was included in this set for install including all hardware. They went on rather easy since they come assembled but I disassembled for paint. Even then there are only 3 major components: Glove compartment, Fairing and upper end cap.
There were two minor snafus in installation.
First the lower crash bar clamp is a bugger to conform to the bar and match up the boltholes. Its rubber coated and I had to reshape it for the hole matchup.
Lastly, the picture below with my finger pointing shows the back wall of the glove compartment that you have as access to screw the nut on the end finishing cap screw. Since it's double walled, it takes a 7/16 socket but the hole is too small to slip the socket thru without a re-drill and a 5/8 drill bit. It added an extra 20 minutes to the first side install but after that I drilled the second glove pocket before installation. As you can see I purchased the vented/Screen model designed for the 103 water-cooled. I figured that I would cover the screens inside (clear heavy duty tape) for winter riding and un-tape them in hot weather. Lastly the actual vent that you direct or block air to the engine and rider did NOT come with the slide lever and rod to the vent as OEM's do but, it’s not a problem for me to manually adjust this metal flap. By the way, the glove doors are metal and magnetic and are much easier to open than OEM. Also, My Fork fangs work without any interference at all! I have now painted the knobs semi flat black.
To sum this all up: Like all the rest, this kit comes in Black only and at $249 for the set and hardware it’s a heck of a good deal . . . . . . . . H O W E V E R,
** If you plan on painting these, you might just as well buy the OEM set pre-painted especially if you get a 10-15% discount like I do because with that, it’s almost a wash in costs. With shipping and paint, I have $540 in these, OEM painted are $700 minus my 15% discount plus 9.25% tax = $654. BUT . . I’m very happy with the thickness and overall quality of these and-I had fun doing this as my winter project!!!
Just throwing this out there but I have heard you can't run the Harley fork fangs or fork wind deflectors. Better test it before you scratch your paint job. I would check it out there is a private company out there that makes them for the Ultras. Pretty sure Hulks has them and posted something about it a year or so ago.
Just my 2 cents
Update: Fork fangs work perfectly with no interference with the Rushmore style lower fairings I bought from Fairing Factory.
View attachment 8801View attachment 8802
Yes, Mine are still on with the new lowers.
Mojo- thanks for sharing your review. Reviews like yours really help people make informed decisions.
Mojo,
Good taste in color! One question if you are able to answer is did your painter use factory paint from HD or did they do a color match? If it was a color match do you happen to have the manufacturer of paint & the paint code/formula they used? Main reason for the questions I do my own painting at home & have been debating on aftermarket vs factory painted tour pack.
Mojo,
He indicated Harley paint at $120 for 8 oz, that's all I know except it's a perfect match.
jdtech17
