Trask Vented Transmission Cover for M8
Stl-BooDog
29
What am I doing wrong????
Installed the Trask vented Transmission cover and got oil all over everything...
I installed it and roughed the hose up under the seat then resting underneath the right side cover.
After riding a while I started smelling oil burning, when I pulled over at the gas station and found the right side pipe and saddle bag covered in oil. I'm not sure how long I was riding this way before this started.
Luckily I was able to make it back home without issue. After getting the bike back into my garage I was able to see just how lucky I was.... The break rotor and the right side of the rear tire was sprayed in oil. Obviously not a good situation...
I'm not sure where I went wrong, has anyone had this issue???20210425_160234.jpg20210425_160257.jpg20210425_160628.jpg20210425_160749.jpg20210425_161729.jpg
Do you have a picture of the trask cover?
Sent from my SM-N975U using Tapatalk
Photos of the Trask cover.
Sent from my SM-N975U1 using Tapatalk
Looks a little wet by the front bolts? Did you remove the factory gasket when you swapped the covers? Are you sure it's coming out of the breather filter?
It is a little wet on the front bolt, but that happened while removing the original cover and factory gasket.
Definitely coming from the filter.
I would recheck oil level and possibly a leak down test. Either oil is over filled or you have a severe case of crankcase pressure.
RoadglideRAS
