Front cylinder and head put on this morning.
128 Stage 4 kit
128 Stage 4 kit
The install and Dyno is done. The total cost is short under $6K. I went with the full Screaming Eagle 128 Stage 4 kit and used the HD headers.
Tuned with Powervision:
HP 127
Torque 136.7 ft-lbs
Install was made by Arsenal Harley Davidson in Waterford, MI.
Over the weekend I mounted the LA Chopper 10 "handlebar.
What a struggle but the result is beautiful
today i ordered rear shock absorbers
Those bars look great! What caused the most difficulty when doing the install?
What shocks did you go with?
the greatest difficulty was to pass the cables internally, at the 90 ° corner point.
I went with BITUBO WME shock absorbers
now I'm looking for mirrors, I see my hands
advice is accepted
Let us know what you think of the Bitubo shocks?
I have the same bars and did this for mirrors. Don't love them, but don't hate them. Got them from Amazon for around $90. Also you can get adapters from KSt I believe that will lower your stock mirrors. Or obviously go up with bar mounts.
Good luck..
#ridesomemore
I like the KST adapter, can it ship to Italy? the cost of shipping will be high for one item only.
Some friends have Bitubo and they are fine, they cost half of ohlins.
Your solution seems the right way
rear Bag rails
rear Bag rails
Always liked these on my older FLH bikes over the years, noticed HD recently added them so had to have a set, & took the time to install them today.
I Like them !
Recently added the spotlights too, I always liked the classic models.. It's cold and bikes nasty so didn't get good pics yet......
Grudge Box, Billet Clutch Basket, Baker Comp, New Shoes and new Grips
Nice, I'm running the Baker DD7 in a 114 with a mild cam. If your clutch hand ever gets tired you can use Rekluse plates with stock spring pressure. I'm using softer than stock springs.
Added a James rocker gasket to the front rocker cover. Was leaking again, smh. I bought a pair, but the back was fine, and I was too lazy to remove the rear cover...also added the upgraded screaming eagle spark plugs and wires, and the Hogworkz mid frame air deflectors....
Did a complete top end to replace a blown head gasket and replaced the factory exhaust and Cobra 909 slip ons with an S&S Sidewinder which sounds amazing.
I added new reach bars and while they were off, New Kahuna heated grips. :cool:
I have the take off Kahuna grips for sale (non-heated).
Replaced my fuel filter today to make it seem like I accomplished something since the rear head is still leaking.
The left one is new and the right one is the original with 58k on it.
Replaced my stock rotor bolts with 12 point polished stainless steel.
El Guero Jay
