I installed the alloy art stabilizer. It mounts to the left side of the engine by the starter and attaches to the right side of the bike. Haven't rode much since the install, has anyone else installed one of these with any results?
Looking forward to hearing what difference it made.
Sent from my SM-N910V using Tapatalk
The Aerocharger is a blast. took me all of 2hrs. I can smoke the tires in 1st and 2nd. I am up to 9lbs boost now . It drove like a stock bike on steroids all the way to Daytona Bike week over 600mi. got good gas mileage as long as I stayed out of the boost. my only complaint is the kit should have come with an spare back tire. If your interested call and talk to Brad at aerocharger. He gave me a killer deal on a complete kit and their customer service was great.
I changed the batteries (CR2032) in both my key fobs today. If your FLHX(S) is over 2 years old you might want to also.
EvilTwin, did you get the intercooler and dual band PCV? Did you look at the Trask turbo kit before making your buy?
Yes, I have the intercooler and the PCV with autotune. pcv autotune is the way to go. aerocharger already had a base map setup. after plugging it up you ride it . when you get back plug in your laptop, check fuel trims. if they are maxed out hit accept it changes your fuel table . keep doing that until they no longer max out. no need for a DYNO. when you are threw you have a custom map for your bike and ridding style.. I looked at trask and a few other turbo kits. Aerocharger was the most complete, cost less, made more torque down low 2500-6000 and the turbo is behind you out of the way of lower fairings. the kit came with everything, injectors,heavy clutch spring, boost guage, pipes, turbo, 5psi and 7 psi spring with 4 .5psi shims, pcv with autotuns. everything for less than $6500 shipped. you can get the whole setup chrome for an extra grand but I just used my stock heat shield .
Getting ready to have CLEARBRA installed on the fearing,front fender, and saddlebag lids, It's a clear 3M film they put on to protect against rock chips and uv and whatever. It has mostly been used on autos instead of the cloth or vinyl bra's comes with a 5 yr warranty.
Had it installed on my wife's Jetta they also do the headlights to keep them from yellowing and othe body parts prone to scratches.
One of the first mods I did as well!! Very worth the money!!
Chaderick, I notice what appears to be a switch mounted under what I think is the seat pan....is it a switch and what is it for?
Late Christmas present from Santa. Installed RF T400X2AD amp with Hertz HCX 165 Hi Energy speakers in the fairing.
Installed ACCEL Stealth SuperCoil and chrome heat deflector. Fired her up tested out the coils with a short 20mi ride to warm things up, 2 burn outs and several practice launches. cooled her down cleaned her up .
I replaced the Chrome HD Fairing vent insert with a color keyed Mysterious Red unit. I applied some Frost King 2 inch tape across my rear fender where the Tour Pack wiring lays to keep it from "scrubbing" the paint finish.
Then I rode about 150 miles today!!!!!!!!!!
I polished the chrome wheels and all the chrome on my bike, topped off the air in my tires, removed the front fork reflectors, detailed all the paint and starred at it for hours and did a little ride as well.
Can we get a pic with vent insert?
