Wild 1 bars and heated grips internally wired.
lenpharleyd
I'm looking to put Wild 1 WO579 CHUBBY® BAGGER LOW bars on my 2016 Street Glide CVO. And add HD heated grips. Wild 1 says all wiring can go internal in the bars. Anyone have experience with this that can verify?
Thanks!
Looks like it wires would install easier on the wild 1 then they did on my twin peaks. Sharp 90 degree angle on peaks, smooth turns on wild 1. 1 1/4" bars should not be a problem.
Have Fun.
That is possible but you will have to depin some connectors, which is easy to do with a paperclip.
The 2016 has smaller connectors that will go through the bars easily without depinning. By the way easily can still be a bitch. I just did my bars a few months ago so I know this 1st hand.
installed 10" on my 14, wasn't a bad install. Definitely easier than the bars with the tight bends would be, just watch out for the tbw cables before you button everything up. Don't ask how I know.
I watched this excellent video instruction no telling how many times to include during my 12" YMB install. Priceless in providing the confidence to tackle, but take your time. Getting all wires inside the bars will be the hardest part.
I installed Harley heated grips on my 15 street glide with 14" wild one chubbies, all internally wired. you need to grind some of the flange for the left side grip and grind a little of the switch housing, also you will need the extension that comes with the grips
jdtech17
