19” enforcer wheel swap on older Harley Touring
JNic2001
Hi all
I have an 06 SG that in doing a 19” enforcer wheel swap on. I want to say the wheel came off of a 17 SG but I’m not sure. So far what I have read for parts needed are
08 and up Brembo calipers
Front axle w/ spacers part# 44-0794
Non ABS bearings.
I’m assuming 06 or older bearings? Can someone clarify that? And is there anything I missed?
Thank you in advance!
The 07 and older bearings are 1 inch or ¾ inch depending how far back you go. In 08 the axles changed to 25mm.
You also need to check if the axle with fit properly in the fork sliders.
Besides the calipers, the rotor may need to be changed too.
Sancho
