Brake light
Nascarrat48
Hi everyone. Having an issue no brake light have replaced bulb checked fuses. Tried a test at the switch leads using a paperclip have power but no brake illumination. Any ideas would be great. Thanks.
Have you checked for any DTC( diagnostic trouble codes) any codes set may help you locate the source of your issues.
2015 FLHXS Amber Whiskey; Thunder Max Tuner with Stage 1; Screaming Eagle air cleaner; 4.5 inch RC Exhaust mufflers; Ceramic coated headers; LED turn / run lights front & rear.
After replacing the bulbs I had one working and one was not. Come to find out I removed - rotated - installed which fixed the issue. The blub needs the correct orientation to make contact. Also ensure you start with a good bulb.
Webike Japan
