Dealer Location Update
How do you know this is a new one there is no date on it? I did a dealer update a couple of weeks ago
I was at my local Harley Dealer yesterday & he told me that it just came out.
My local Harley shop ( Hells Canyon Harley ) was not in the database, it is in the new upgrade.
I would assume the latest software update is required for it to work properly. Under Improvement and under Fixes on version 1.20.2 it mentions the dealer update options. I loaded 1.20.2 then the dealer update, it recognized the dealer update automatically.
Boom! Box 6.5GT
Date Released: 10/17/2016
Version: 1.20.2
Change Log:
Improvements
· Support for quarterly dealer database updates and database version screen.
· Switch to call screen when call initiated from phone.
· Headset sidetones added for CB.
· Prompt user to transfer active call to device at key off.
· Default zoom level set for Maneuvers.
Added Features
· Siri functionality has been added. Hold Voice Recognition button for 5 seconds to activate.
· Added media browsing over Bluetooth for iPhone.
· New feature to allow searching for another address while still having an active route.
Fixes
· Allow Nav and Dealer USB update prior to Navigation Loading.
· Post Code entry for HDI and ROW radios has been re-enabled.
· Media pause after fast forward.
· Activation code issue when USB drive is removed and reinserted.
· Navigation data fields no longer overlap next turn during recalculation.
· Japan radio shows Setup button twice.
· Weather map zoom level persistence.
· Passenger Intercom volume shows “off” when driver adjusts.
· Prevent import of Nav destinations with incomplete data.
· Media remains paused after multiple rapid prompts.
· Roadway icons overlap in traffic list.
· Improved indexing time for USB devices with large numbers of media files.
· Bluetooth connection persistence.
· Performance and stability enhancements.
Just downloaded the new updates.... the dealer update/navsync is not working.... stuck in authenticating loop... give it a few days... there may be a glitch....
Sent from Note4 via TapaTalk
Mine updated just fine yesterday, each update needs to be in the root directory, I used two different flash drives, one for the Boom update & one for the Dealer updates
Did that... dealer update just spins in authentication... I'll try again tomorrow.
Just the ISO for the dealer update, correct? I'm sure it's the same as every other update
a TRICK to get it to work a bit quicker
I used all files from the extracted .zip file for the dealer update
Correct Grizzly24... you need the extracted ISO file and the NAVSYNC folder as well... thanks!
I did find a trick on CVO forum that works a bit quicker to load....
1. Turn Bike to ACC
2. Hit ACCEPT Screen
3. Hit NAV button and WAIT for NAV to be fully functional
4. Insert thumbdrive and away she goes!
Only took less than a minute with one package....
Thanks again!
Just a note here... I did mine and a Brother's 15 Limited... both of us have issues along with 2 others that I talked to on the ol interweb. ..
After the successful update.... went for a ride... no issues... stopped... got back on.. started... HU dead. Stuck on Bar and Shield. Turned it off for a few minutes.... back on and all was good... til we stopped for gas. Started up and same thing... turned it off for a few... then back on... all was good.
Just letting you all know.....
I may back peddle to 1.20.1 until something is fixed.
Spazz- Same here. Worked fine until I shut it off and started the bike again:
No external buttons worked
Couldn't turn head unit on or off
No music in any mode.
I reloaded prevous version and was back to normal.
screw this latest firmware!
Just download the 1.20.2l to my 2017 SGS and now I have....NOTHING!!! but the bar and shield and the time.
Does anyone know were I can get the 1.20.1 version to install until they get this fixed?
Thanks in advance for any help
Mojo... Let us know if you have any issues after going back to 1.20.1.... wondering if the dealer update may be the culprit here.....
thanks
Just downloaded 1.20.2l and now have nothing but the bar and shield and the time, no controls work.
Only had the bike for 3 weeks so don't have a copy of the previous version (1.20.1) does anyone know where I can get a copy till they fix 1.20.2l?
Thanks in advance
I just tried mine for the first time after updating a few days ago. When I first turn the ignition on, I get the bar and shield and no controls work, but the radio plays. After a few seconds, I get the warning screen and everything works as normal. I did the 1.20.2 update first, then the dealer update.
SG82
