Hogworkz LED replacement bulb vs Complete Hogworkz LED headlight
rajevan
Has anyone had the expirence of just upgrading the halogen bulb to an LED, or is swapping to a complete LED Headlight preferred? What are the Pros and Cons
I've heard of people with other bikes having problems caused by the replacement LED bulb not being exactly the right length, causing the standard reflector not to work properly and causing less-than-perfect beam focus.
I don't think this is popular here on the forums but I have the TruckLite and I love it. Personal opinion only.
Less than $100 off Amazon and I had money do throw towards other accessories.
7" LED Headlight For Harley Davidson MOTORCYCLE CHROME PROJECTOR DAYMAKER HID LED LIGHT BULB Jeep Wrangler LED Headlamp
I did it with a Sylvania bulb and it think it works great!!!
The light is now white vs the factory yellow, I have a nice lighted area in front of me at night and while some have complained about radio interference I don't have this as I have my iphone mounted directly infront of me on an Iron Aces maount and hardwired into the USB port so busic is clear and the best part is........I don't have to use the POS GPS that is built into the Boom Box :D
In any case I like it and mine was around $65 on Amazon.
PS....do the search on Amazon....I do NOT remember which one I used and I'm too lazy to look it up:cool:
I put the Cyron LED H4 replacement bulb in my 2010 Ultra Classic before I traded her in and the bulb did make a huge difference at night. There wasn't much of a difference between high and low beam but when I added the passing lamp LED replacement bulbs I was very happy with the light I got for night riding. Now I traded my Ultra last fall for a 2016 Street Glide Special and installed the passing lamp kit on her. I put the passing lamp LED bulbs I kept from my Ultra and they are bright as balls...the only issue I have is I can't use the H4 LED in the new street glide as the street glide uses two different bulbs in the headlight. I contacted Cyron to see if they make the two bulbs I need.
Webike Japan
