Playlist question
flhrci
118
I figured out how to make them with a software program and it worked. Question is, how do I stop the playlist playing and go back to the regular music?
David
As in a radio station? You push IN the lefthand toggle switch and that switched the infotainment system between FM/AM/WB/
As in USB playlist actually. Want to stop the list of songs from playing and go back to normal USB operation. The playlist I made has 269 songs in it but the USB has 0ver 7000 songs that I cannot access because of the playlist. All I can come up with is delete the playlist file with a PC and reinsert USB drive.
Its been my experience that ALL songs have to be placed in a linear order on the USB stick. Boombox cannot access or switch to different folders.
I forgot to report on my fix to this problem.
I deleted the playlist off of the USB drive and plugged it back into the bike and started her up. After the radio booted, it played the last song like usual but it did not have a track number at the bottom of the screen. When the song was done the Radio said "playback stopped" and did not do anything else. After two reinserts of the USB stick the radio finally reverted back to random songs from the USB drive.
So, for right now, until I can make multiple playlists, I am not doing that again. Deletion seems to be the only fix right now to make a playlist stop because just pulling and reinserting the USB stick does not work to interrupt the playlist.
2014FLHXS
