PRE-WIRED Yaffe chrome 10” bars for 2014+ batwing
FX44AU
64
These bars are used but in excellent condition. Only reason for selling is because I decided to go with higher bars. Most of you already know this but Yaffes are taller than listed; these are more like 12” bars. I can send pictures via email or text. You’ll be getting the bars with wiring for left/right switches and TPS assembly with wiring. Stock clutch/brake lines work perfectly fine. I do believe Harley changed the TPS connection at some point (I think in 2016) but I have pictures of the plugs for you to confirm. Mine only used the plug that is directly in front of the ignition switch cover. The other one must be for something else. Mine is a 2016 so I know they fit 2016+. I am not including the switch housing but they are easy to swap out from your existing bars. Disconnect the plugs on each one and plug the wires that are already in the Yaffe bars back in. It's that easy.
$485 shipped for the pre-wired bars
$525 shipped for the pre-wired bars with Kuryakyn Kinetic grips
$565 shipped for the pre-wired bars with Kuryakyn Kinetic grips and Arlen Ness mini ovals
jjmuskie
