Rear brake gets hard
gwimm
5
I have noticed at times my rear brake is hard as a rock and no braking power, if i step on it two or three times hard it will come around, usually notice it after it sets for a while (2016 glide with abs)
thanks
Speed dose not matter you notice it the first couple of times you hit the brake, could be 15mph or 40mph, it seams to be after i wash it, most of the time i wash it then put it in the garage for a week, so the next time i take it out it will do it
sounds like a bleeding is required, you have an ABS indicator on dash, it should flash ready when self test is complete. do you have any faults codes?
No codes, abs light flashes like it should, going to the dealer and I believe they are going to bleed it and see where it goes, I was more interested to see if anyone else has had the same problem
chrisw0529
