Screaming Eagle Ventilator
cc424
17
Ok, so I was replying in another post about how to change an air cleaner out and it made me realize that I had a question about mine. I recently changed the cleaner out and added an fp3. Now when I start the bike up and decide to give it some throttle. It feels like it's dying out. But if I let it idle for a couple minutes then I can whale on the throttle no issue. Is this normal or am I missing something?
The FP3 can make your bike run better or it can make it run worse. You need to work with it and give the bike some miles to adapt.
OK...Still in the autotune process but just curious if anyone had experienced the same. I was worried that I didn't install the cleaner right but I guess you can't mess it up. You put the gasket on then screws next....thanks for the replies!
jdtech17
