My speakers started beeping a couple of weeks ago due to what I thought was a battery that needed to be replaced. I have swapped out the battery and took it for a ride and the speakers are still beeping with and without the radio on. Any ideas?
Try turning your ignition on and immediately pulling the main fuse.... turn ignition off...wait two minutes... reinstall the main fuse.
Should reset the system.. but maybe not...
I have only seen this one other time... battery was drained and took out the regional code in the head unit. Check your head unit regional code.. I can't remember if you can do it yourself or you might have to bring it to the dealer
Thanks for the great advice! However like you said the issue with my battery did wipe out the code, so I have to go back to the dealer so the bike and info system (nav/radio) can be remarried. Nothing I can do from home.
