What app do you use to play your music on you SG, either BT or plugged in.
easyrider7467
23
Hello,
I've done a few searches but haven't found anything. iPod is an option however is their app that I can download to iPhone. Thanks in Advance.
A thumb drive loaded with music and plugged into the connector behind the right hand panel works for me.
I need to load up a Thumb drive my self, A friend uses one on his 2013 road glide, Works crystal clear.
I'm loading up one as I type..
Always used an Ipod until I started using the jump drives. A brother told me about an app you can down load called MP3 rocket and the sound quality is amazing using it.
Been using Amazon Music for a while now. You can save songs for offline listening (great for backwoods rides), or kick on a radio station similar to Pandora, except no ads (if you have a Prime membership) and you can skip and reverse through songs as many times as you want. Apps available for both Android and iPhone.
I currently use Amazon music and Iheart radio.
Iheart radio comes through much louder than other apps (Google Music, Amazon, Spotify) though, not sure why..
Hello,
I currently am using the CarTunes app for the iPhone. It plays all of your iTunes music but allows you to use it in either the vertical or horizontal orientation. It also allows you to "swipe" left or right to advance songs and "tap" the screen to pause / play. I highly recommend it.
Hope this helps!!
Lindsey :0)
Is there any particular size thumb drive that works or sounds better than others? How many songs will one of these things hold?
Well I have a couple that are 256 gigabit's and the sky is the limit. Make sure you check it out before buying and it will say for music. But others I have will do the same.
Hope this helps!!
Lindsey :0)
Im not finding “CarTunes”? Is that the name of an app or am I missing something?
2014 Harley Davidson SGS
Found it but it hasn’t been updated since 2013 and won’t work with the current iOS.
2014FLHXS
