When alarm arms, no audible warning?
havinabubble
May 27, 2019
78
my missus has a 2019 FXBB and the moment her bike is armed it chirp chirps and flashes
when my 2017 FLHXS arms, I just see turn signals flash and no chirp
is this something the previous owner may have turned off?
can I turn it on somewhere in the settings?
TIA
It should flash lights from factory setup. IF you want siren and chirp there are 2 options:
1-Buy the alarm module from dealer (appx $100)
2-Buy a $7 Piezo alarm module (got mine at radio shack).
It does the very same thing except does not have a battery backup inside.
It's a 2 wire hookup inside the left side panel.
Really? [emoji50] doesn’t come with siren as standard?!
I read another great post on how to fit the cheaper option so might go that route if it bugs me enough
cheers for the explanation [emoji1303]
You know Harley- They option everything. I've been doing the Piezo module on my last four bikes and it works well and is cheap and easy to install.
thanks to being a YouTube Certified Mechanic [emoji327][emoji1009]
I found a vid on how to disable the chirp!
Turns out the previous owner had disabled the audible chirp on my 2017 Special
Irritating tone restored [emoji86]
Qman77
