http://www.ddmtuning.com/Product-Categories/LED-Bulbs-Lights/Tail-Light-Turn-Signal/1157
What cha thank about this?
I use CD... I always get told how bright the tails are.... the full disc encompasses the entire bezel and super bright. I run CD dynamic rings up front which are white and blink amber...
Harley day maker here to
And YES.... there is a difference between the HD installed Daymaker and the Daymaker you buy from the parts guys.... Take a close look....
FACTORY Daymakers have low and high beam lenses are IDENTICAL size... the others have a larger high-beam lens on the bottom like mine.
Dealer installed is not the same as factory installed... look at picks of the limited headlamp... then look at what the dealer sellsMine was Dealer installed
Interesting Spazz. I did not know that! Does it make a difference in the beam throw??
Why would they make two different projector LED headlights? I'm gonna have to check this out. Gotta got to the dealer tomorrow anyhow.
Yep.. and a lot more money from what I understandthat is wierd wonder if the part numbers are different
The one with the larger lens on the bottom is the latest design from JWspeaker: model-8700-evolution-2
