2016 gas tank hard to fill
bigguns55
16
Anyone know the secret to filling your tank without making a mess. Tank door is always in the way and no matter what gas always spits out.
Park so the right side of the bike is facing the pump. Hold the pump with your right hand, and the hose with your left, and the door will be out of the way. Fill the gas slowly, and do not top it off. Ever.
I agree with you that the door does get in the way. IMHO I believe that the MoCo could have allowed the door to open a little more making it easier to fill the tank.
15 SGS Amber Whiskey; ThunderMax tuner; Ceramic True Duel headers; 4.5 inch RC Exhaust slip ons ;LED turn signals/ run lights; passenger backrest; one inch passenger and rider floorboard extensions;stage one air cleaner.
fill it slow and easy try to stand to the side in front of the tank so you can monitor the progress// if they would have made the tank door to open the opposite direction it would have made filling easier just my opinion
maybe some after market parts maker will make one one day sure they could sell them
mule
I thought I was the only one. I think I fill it neatly 1 time out of 10 without splashing.
The door either needs to open wider or the other direction. It's kind of crazy how something so simple was made to be so difficult.
Yes fill the tank slowly don't just crank it up and wait for it to shut off. The reason the door is like that now is because if it was the other way and you were in an accident sliding over the tank and door comes open you loose your manhood.
Just my 2 cents
maybe they could do it like the old fat bob tanks put the fill cap on the right side of the tanks
makes more sense the fill position would be on the high side when bike is resting on the stand // eliminate the problem with the hinge // you could fill standing on the side visibility and control would be better
just my opinion
mule
That is one of my big complaints about this bike, the tank door arrangement. I also found the stock bars get in the way so I park at the pump with the bars turned fully to the right (filling on the left). A tank door that doesn't get in the way would sure be nice!
If you really want every ounce of gas possible, slowly fill it to the neck then shake the bike to break the air bubble. I can do this 5-8 times before she's 'really' full.
That's my technique and it's the best way I've found. I rarely spill over but it will happen if you rush it.
I sit on my bike when I fill it. I pull right up to the pump's credit card slot and shake the tank a time or two while filling.
Actually, my '16 SGS is one if the easiest to fill. I'm right handed but park so the pump is on my left. I hold the nozzle in a very upright position with my left hand. And my right hand is guiding it also. The hose never touches my bike.
BTW, with the V&H Power Duals and FP3, I went 264 miles in 4.9gal. That's 53.8 mpg. Damn good I think.
Here she is
Living in California, we get to have the additional
Snorkel recovery on the gas nozzle. When fueling up any of my bikes I pull that back and watch the fuel fill the tank . Never any problem with this
I guess I have been lucky....never had much of an issue putting gas in my tank.
Maybe the dealers need to have classes on how to fill your tank??
Dang it...someone beat me to it....the 'advantages' of living in California.....where it takes three hands to fill your tank.
I'm with doc_63 on this method. Grab a couple of window wash towels from the dispenser and hold under the bottom side of the nozzle, fill standing on the left side as the bike leans into the side stand. Occasionally I have had to fill standing on the right side with bike leaning away which seems more cumbersome and I have torched my leg on the hot pipes a couple of times doing that. Ouch!
I do the same. Thinking if Harley would switch the latch so that it opens away from the rider it would be much easier.
Webike Japan
