Ok got it out in the dark WOW what a difference over the stock one. I can see now I could before but now you see everything and for a long ways too
How does it look on the SG ?
Look stock or does it stick out further then the stock headlight ?
It looks the same maybe a little flatter on the face but fits the same
Hulkss does this fit in the stock Harley adjustment ring or did it come with a different one?
Fits the stock ring on 14's and 15's not sure on the older ones some needed a new ring.
Just got this light from Amazon and what a difference, and cheaper then the one Harley sells and it came with a life time warranty ez to install just buy the pig tail from the dealer will strongly recommend:
Whats the price for this new model, I spent $419 for the HD light.
Got mine for 330 Mojo just shop around a little
Yeah I paid 344 plus free shipping on Amazon. Can't wait till this weather breaks and I can try it out.
The Daymaker is the same as the 8700 (until Harley upgrades). See earlier posts in this thread.
Is this a must have? I've only ridden one night in the dark, but it was about as bad as my sportster. That being said, I may want to add LEDs to the crash bar - but want to look around a bit. Since this doesn't really change the look of the bike (I like that it doesn't) is it a dramatic change at. Night?
Also, is it correct to assume all I need to order is the 7" light? The stock ring will work and no modulator is necessary?
I have a 2015 SGS
Thanks!
Yes the 7inch light is the one. You will need the harness for another 25 bucks from Harley and it plugs straight in the loose wires just get tied up as they are for another model.(Shrink rapped mine) You can find all the numbers somewhere in this post if not I can post them again.
This light is one of the best upgrades I have installed thanks Hulkss for keeping us informed
On the install, do you connect the blue female/male flat connector together? Also, there are two loose wires, one blue and one black with shrink on the end of the black wire, do these go anywhere? Thanks
Here's the instructions:
View attachment J05884.pdf
"The two capped wires are not used. Secure to the jumper harness with electrical tape."
"The fourth wire on the LED adapter harness is not used in all cases. It is for the position light on some headlamps."
Wiehe13
